Should I change any parts in this build?
Benisthebest
Commendable
Aug 20, 2016
36
I need some suggestions about my build.
First, I need to stay under $1400.
My case is the Corsair Vengeance C70.
My motherboard is the Asus x99 Deluxe (not deluxe II).
My cpu is the i7-5820k.
My ssd is the SAMSUNG 850 PRO 128GB SATA III.
My OS is Windows 10 Pro 64-Bit.
My CD/DVD drive is Samsung SH-224FB/BSBE
My GPU is ASUS GeForce GTX 950 2GB
My ram is HyperX FURY 8GB 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Desktop Memory Model HX421C14FB/8
My heat sink is Cooler Master Hyper T4 CPU Cooler with 4 Direct Contact Heatpipes RR-T4-18PK-R1
My extra fans are APEVIA AF212S-BK 120mm 4pin & 3pin Silent Black Case Fan (2-pk)$
My PSU is the EVGA SuperNOVA 750 G2 220-G2-0750-XR 80+
The final price is, 1,341.95 (including a keyboard that I need)
Thank's to all!
A good quality 350 or larger PSU would be fine. The GTX 950 only requires around 90 watts, the CPU, 140 watts. The rest of your system will only be using another 20 or 30 watts still leaving you plenty of headroom. Corsair has the new CX450M, which looks to be a good value.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($369.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard ($219.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (4 x 4GB) DDR4-2400 Memory ($74.98 @ OutletPC)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: MSI GeForce GTX 1060 6GB 6GT OC Video Card ($259.99 @ SuperBiiz)
Case: Corsair SPEC-02 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($19.98 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($129.83 @ OutletPC)
Case Fan: Corsair Air Series AF120 Quiet Edition (2-Pack) 39.9 CFM 120mm Fans ($25.88 @ OutletPC)
Total: $1333.09
Generated by PCPartPicker 2016-08-20 08:37 EDT-0400
