jozef161 Distinguished Jan 18, 2013 19 1 18,515 May 27, 2018 #1 I am relatively new to overclocking, several months ago I set all cores on my 7820x to 4.5 Ghz, however, I still let the intel turbo boost 3.0 run in the background, should I disable it? Does it have any impact whatsoever? Thank you!
Solution feelinfroggy777 May 27, 2018 When you overclock the chip the CPU is no longer using turbo as you have changed the frequency multiplier. There is nothing you need to do.
feelinfroggy777 Glorious Dec 13, 2016 5,721 135 45,990 May 27, 2018 Solution #2 When you overclock the chip the CPU is no longer using turbo as you have changed the frequency multiplier. There is nothing you need to do. Upvote 0 Downvote Solution
