Question Should I keep 1500 Mhz clock on each ram stick for a total of 3000 mhz or clock both ram sticks to 3000 mhz each?
CurseOre
12
I have a ryzen r5 2600 and two sticks of 16gb 3400 ram. 3000 is the speed I would like to reach since higher speed is optimal with a ryzen chip. This said, when I overclock the ram, the speed is split between the two sticks. Should I clock the dual channel to 6000mhz for 3000 mhz on both sticks?
Please post the memory screen of CPU-Z. And list your motherboard please. You may be mis-interpreting what you are seeing.
Both sticks should run at the same speed. And enabling XMP (or A-XMP) should be all you need to do to run at full speed.
