I have a computer from about 2013 that I bought as a pre-built and later moved components into a different case. These are the specs:
i5 4670 3.4 GHz
Weird Custom Motherboard from HP that has weird CPU cooling mounting holes and custom 6 pin power cable.
8 GB (2*4) DDR3 1600 MHz memory
2x 500 GB HDDS
AMD R7 240 2GB (oof)
240 Watt 80+ Titanium(maybe platinum) PSU
I was thinking of getting a new motherboard and maybe some more ram. I was also thinking of getting something along the lines of an RX 5600 XT. I don't know if that would be a big bottleneck or not.
or...
Should I just buck up and buy a new system and sell the old one. If so, do you have any suggestions for the 500-600 dollar range?
Thanks.
i5 4670 3.4 GHz
2x 500 GB HDDS
or...
Thanks.
