I have a Cooler Master 690 iii and I don't know how to configure my fans. I have one 200 mm fan at the front, which is pulling cold air in to create airflow in the case. At the back there is one 120 mm fan pushing hot air out of the case, and at the top 2 140 mm fans pushing hot air out of the case. I have an extra 200 mm fan in the side panel too help cool the mobo and gpu, but I'm not sure I it should blow air to the video card or push it out of the case. Perhaps I'll also add one 120 mm at the bottom, and I'm not sure if it should push or pull as well.
