HELP PLEASE!!!
I just need to know whats wrong with a new system build I have completed. I have just put together a new system comprising of a Gigabyte Motherboard a GA EX58 UD3R complete with 6gb of OCZ XTC Platinum 1333mhz Triple Channel memory and an Intel Core i7 930 CPU all running at stock speed. I installed Windows 7 x64 ultimate and everything is fine.
The problem I am having is that when I come to shutdown my system, the screen says its shutting down and for all intensive purposes my monitor then goes blank but my system does not do anything else, it stays on and even after 10 minutes, its all just the same?!
I have absolutely no idea what is causing this problem and am really annoyed?! Is it the motherboard? The memory? The Bios? I am at my wits end, and the only way I can switch off is to hold down the power button and switch off manually. I am worried that this may be damaging my system? And even after I have switced off everthing that way, the number lock light on my keyboard and the light inside my optical mouse both stay lit? Again I cannot figure out whats causing this?
I would be really grateful if anyone can give me some serious advice on this I have seen similar posts for similar problems from other people but nothing that could explain my problem?
PLEASE HELP, THANKS!!!!!
