[SOLVED] Signal disconnecting and crashes... graphics card issue?
GangstaSlime
64
Somewhat recently, I've started getting this issue that seems to occur in a few different places:
Basically what happens is I'll turn on my computer, my monitors turn on, and then my monitor has a black screen for up to a minute before it shows my lock screen. (it used to be literally a few seconds)
The other time it does this is when I change my screen resolution in a game. I'll click to change the resolution and the screen will go black, turn on and off multiple times (the monitor), display "no signal", and then the process repeats for a minute until it has adjusted (this also used to take seconds).
This is another weird issue I'm having that I think could be related to the previous:
Sometimes after my computer has been on for at least an hour, all of my monitors will turn white with vertical lines (typically blue or gray). After about 10-15 seconds the audio I had playing stops and it doesn't shut down by itself like a normal bluescreen crash, so I have to hard shut-off/reset. I don't think it's an overheating issue because when I run a resource-heavy game it won't ever do it, only when I'm doing something simple like watching Netflix or looking at sites like this.
I originally thought this was a problem with my old hdd, but I tried replacing it with a new ssd and I'm still getting the problem. I've also tried updating drivers, using different monitors/different cords, and I don't have another card/pc to test with.
Thanks for the help 😀
**Specs**
x2 - MSI AMD Radeon R9 270X Gaming 2GB GDDR5 Graphics Cards
x1 - MSI ATX DDR3 2133 Motherboard 970
x1 - AMD FX 8350 Eight-Core 4GHz
x1 - Corsair AX1200i PSU
x1 - Noctua NH-D14 6 Dual Heatpipe Dual Fan Heatsink
x4 - Kingston HyperX FURY 4GB 1600MHz DDR3 CL10 DIMM RAM
x1 - WD Blue SSD (1tb) WDS100T2B0A
x6 - Fans of various brands and sizes
