Silent, Dust free and Small mATX Case?
TechiCanadian
45
Hi,
Im looking for a new case for my current mATX build. The case that i am currently using is the BitFenix Colossus Micro-ATX. Although I love the look of the case, I can't take off side pannel without unplugging front IO plugs. As well the case is not silent whatsoever. You can hear all the vibrations...
So im here to ask you for a case that would be portable because i move from house to house every 2 weeks, so something small that can still fit my GPU (GTX 970 SSC).
I also want to the case to be dust proof, or atleast have dust filters where its needed. Because dust ruins everything 😛
Last but not least I want the case to be silent, something that will capture all the vibrations from fans, hdd and etc...
Quick resume:
- Silent (providing rubber for hdd and pading for panels if possible)
- Dust proof (providing dust filters for all intakes)
- Portable (easy to move around)
Thanks in advance
-Byron L
Not sure if the Fractal Design Define Mini has dust filters, but it is absolutely silent and certainly portable. It's a bit large for an mATX case, but it's certainly too small to call a mid tower. So it's portable and silent, and if it's anything like the full sized models, it should have dust filters as well. Check it out.
http://www.amazon.com/dp/B0085RR0TY/?tag=logicaincrem-20
