I Inhmayz Reputable May 22, 2014 31 0 4,540 Oct 3, 2014 #1 Hi all, Can someone please tell me where I can get a silent case fan? 120mm please! I just bought this http://www.coolermaster.com/cooling/case-fan/sickleflow-120-2000rpm-green-led/ and it's louder then my default stock case fan please any suggestions!
Solution dottorrent Oct 3, 2014 Because you chose a static pressure fan. It's not meant to push air out the case. It's meant for heat sinks and radiators. Pickup either a BeQuiet SilentWings 2 120mm or the Fractal Design Silent Series R2 fan.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Oct 3, 2014 #2 Corsair AF series or Aercool DEAD Silent fans. Upvote 0 Downvote
dottorrent Honorable May 20, 2012 1,883 1 12,460 Oct 3, 2014 Solution #3 Because you chose a static pressure fan. It's not meant to push air out the case. It's meant for heat sinks and radiators. Pickup either a BeQuiet SilentWings 2 120mm or the Fractal Design Silent Series R2 fan. Upvote 0 Downvote Solution
