Question SILVERSTOVE GD08B-x / Bottom Front fans mod question
DREDKNOT_2077
142
question an your thoughts please
the question
iv just bought the GD08B-x for my htpc/server build an im sticking with all air cooling but one thing i dont know before it arrives is for the front bottom intake using
3 x 120mm 25mm thick fans is ther enough room for adding this 20mm fan duct mod to each without having to remove the twin 5.25in bay ?
your advice an thoughts
an a side i was planing to expand the ventilation on the top to mount 2 x 120mm fans for exhaust using a custom wood or metal drill guide for my drill-press like this
rich text editor image
an put one over the gpu area an one over the mobo/cpu spot
so i could go with a 120aio mounted offset farther back an as a top exhaust if ther was enough clearance between the aio pump hear an the under side of the aio's rad
thinking a arctic freezer II 120mm or maybe a 240mm
my gou is a 1 slot wx amd to be vertical mounted.
v2_120mm_fan_m_vent.eps
You could go with slim fans, that are 15mm in thickness, like these;
https://noctua.at/en/nf-a12x15-pwm-chromax-black-swap
then add the ducting but I don't see you using a duct that's height is 15mm over a 25mm thick fan on the bottom venting space of the case, while having both 5.25" drive bays functional with an ODD.
with the 90deg shroud under the bays do you think a 10m on top of a 25mm fan would fit ?
