There is a GeForce RTX 4060 Ti with single-slot blower cooler, but will it be available widely?
Single-Slot GeForce RTX 4060 Ti with Blower Emerges : Read more
It's very easy when you're told to copy&paste the link on literally every article that mentions a graphics card.I don't really understand how you can call a mid-range cart which most serious reviews calle dead on arrival or advised strongly against buying unless you want nvidia tech, one of the best graphics card around.
It may not be all that good for gaming, but I dabble in 3d art (Poser & Stable Diffusion) and I would love one of these.I don't really understand how you can call a mid-range cart which most serious reviews calle dead on arrival or advised strongly against buying unless you want nvidia tech, one of the best graphics card around.
NO! People hate mini DisplayPort as long as said device using mini displayport doesn't come with an adapter.It should've used Mini-DP & Mini-HDMI ports to allow for a larger exhaust port.
You just solved your own problem, include a working adapter inside the package.NO! People hate mini DisplayPort as long as said device using mini displayport doesn't come with an adapter.
Yes, that is the solution to my own problem, however, most of the time the adapters are not included, which means that unless there are adapters included for said mini-DP GPU, the only solution is to not use it all. The whole reason people hate it is because they have to go out and buy an adapter.You just solved your own problem, include a working adapter inside the package.
They should include one Mini-HDMI & Mini-DP adapter by default, any extra adapter is up to the end user to purchase.Yes, that is the solution to my own problem, however, most of the time the adapters are not included, which means that unless there are adapters included for said mini-DP GPU, the only solution is to not use it all. The whole reason people hate it is because they have to go out and buy an adapter.
That sounds fair.They should include one Mini-HDMI & Mini-DP adapter by default, any extra adapter is up to the end user to purchase.
How does that sound? Fair from the Video Card Vendor?
Yeah, that seems like a potentially bad mistake. Barcodes can be read even if they’re 80% covered as long as the full length of the code is still shown.I hope for the leakers sake that middle barcode isn't anything identifiable. They left the entire bottom portion uncensored
