Hi,
I am considering the following to upgrade my CFD processing power (currently i have an i7 920 OC on air 3.9Ghz stable):-
1. Getting a skulltrail (a pair of QX9775;unlocked multiplier version of X5482)
OR
2. Getting another i7 920 and link to the existing i7 with a LAN cable to do parallel computing.
I have read a report "hxxp://techreport.com/articles.x/15818/13" that gives a rather poor review of the skulltrail ability to handle CFD work.
I have also reviewed CPU mark, for the skulltrail the score is 9459 while the i7 920 OC is 6700+, which gives the skulltrail about 40% performance over the i7 920. Considered the skulltrail CPU is not yet OC (i understand that these CPU can be OC upto 4Ghz on air), that will place the skulltrail somewhere 75% better performance than the i7.
The cost difference between the two systems is about USD$900.00, the skulltrail cost more.
I would appreciate any input which of the two systems can provide better CPU power for CFD work.
Thanks in advance 😍
Lawrence
OR
Thanks in advance 😍
Lawrence
