Well, I took the guard's advice and have decided to stop lollygagging on upgrading my gaming PC. Skylake it is! BUT It seems that most, if not all Z170 mobos are having MUCH higher than normal negative reviews. I have usually stuck with ASUS's higher tier motherboards in the past, but like the others, bad reviews abundant. Can someone throw me a hint as to a good board(s) I should look out for? My budget is open to whatever is the best for the price.
Needs: ATX, OCing obviously, Multiple GPU capable @ x8/x8, Native 7.1 capable if Pcie for soundcard is blocked by multiple GPUs, and USB charging when powered off. Also, good cooling (vrm's, nb, sb, etc...) as this build will be a fourth stringer in my workflow when not gaming, and may need to run continuously for days on end.
I really like the Sabertooth (Matches my GPU's and PSU, as well as my hopefully okay to use Noctua NH-D14), but reviews are leaving a bad taste in my mouth. Should I wait for revisions to come out, or do you think they will just drop features instead of adding new ones?
Finally, I have a few dozen coolers laying around, but have heard some bad mojo about Skylake and common coolers not meshing too well. So, I would like some feedback about this if possible, and a good air cooling heatsink recommendation to hold me off until I can run a custom loop through the system. Otherwise, is my Noctua NH-D14 fine for Skylake?
This is what I have in mind:
i7-6700k
NH-D14 (or?)
Sabertooth Z170 (or?)
2x Sapphire R9 390X
SeaSonic X-1250
Corsair Vengeance LPX 32GB
Samsung 500GB SSD
2x WD Black 4TB
Corsair Vengeance C70 Mil Green Case (I like the color, know of anything similar?)
Thanks for your time!
i7-6700k
NH-D14 (or?)
2x Sapphire R9 390X
SeaSonic X-1250
Samsung 500GB SSD
2x WD Black 4TB
