Skyrim 1024x640 resolution issue
Nomad0078
9
Hello,
I've got a resolution issue with skyrim i can't find a related forum anywhere. Before skyrim, i was able to play oblivion, f:3, f:nv at 1024x640 res without any problems. However, when i set my res to 1024x640 in the skyrim launcher and try to launch the game, it gives the error,'failed to initialize renderer. Your display doesn't support the selected resolution. Please choose a different resolution'. I can still play at that res for previously mentioned 3 games, why not for skyrim ?
I don't if it's been said clearly yet, but a 1024x640 resolution is not a standard resolution for any monitor,gpu or game.
Back before widescreen monitors and TV's were sold, most games would only allow you to choose the standard 5:4 aspect ratio resolutions. Those were: 640x480, 800x600, 1024x768.
As widescreen monitors and TV's became popular, OS's, GPU hardware, drivers and games got better at supporting non-standard and 16:9 aspect ratio resolutions like 720x480 (480i/p), 1280x720 (720i/p) and 1920x1080 (1080i/p).
The reason I typed all of that crap above was to give you an idea of how many resolutions gpu's support now. Just because Oblivion and Fallout run at the non-standard resolution you chose doesn't mean any other game...
Specs : i3-350m
ATI Radeon HD5450
4gb ddr3 ram
I know my graphics card is the bottleneck here, but if i could run fallout 3, fallout new vegas and oblivion at 1024x640, why not skyrim ? It's not like the game lags or anything..I just get a message saying that the res is not supported..How come it was supported for the other 3 games then ?? 🙁
its an unsupported rez for the game... theres nothing you can do about it. other than ask the nexus community for a patch... you may get lucky but i doubt theres much of a demand for such an odd rez.
1024/768 is the normal 5/4 rez and your monitor is more likely to like that as its a standard rez. that nearly all can handle.
I don't get it..if it doesn't support the res, why is the option present in the game launcher ?
But I have played fallout 3 and new vegas at that res on this very GPU !
The reason I typed all of that crap above was to give you an idea of how many resolutions gpu's support now. Just because Oblivion and Fallout run at the non-standard resolution you chose doesn't mean any other game will.
If I were you, I would change Skyrim's resolution to one that fits the aspect ratio of your monitor. If you have an old-school PC monitor, it would be a 5:4 resolution, and I would set Skrim to 1024x768.
If you have a widescreen monitor or TV, which has a 16:9 aspect ratio, I would set Skyrim's resolution to 1280x720. If that runs too slow, set it to 720x480.
