Skyrim hip gap after deleting everything and fresh install 5 times!
Lucian28
86
hi im a skyrim modder, i used female body mods like UNp CBBE etc.
but i gap in the hips (specially when crouching) started appearing in my character
so what i've done is re install my game to have it back to default again,
but it kept appearing i even deleted my mods and nexus manager, i even start a new charater thinking it is my game save's fault, i re installed the game for 5 times now but its still there
i can't post images coz i already deleted my game in frustration.. but i still want to know a way to reinstall skyrim without those hip gaps..
Did you delete all the files which are stored in skyrim folder which is under my games in documents/my documents as if you haven't, skyrim will still be using the same settings as the first installation which would be causing your problems
yes i did delete files under my game/skyrim folder (all of it)
i might try to download skeleton stuff only i don't know where to, i remembered i was using those xp32 skel because it was required for FNIS it was causing troubles back then,..
I believe it is because of your armor, not your skeleton. You need to read The Skyrim Repair Manual, and be sure to follow each step exactly: http://www.scribd.com/doc/226935923/JJ-s-Skyrim-Repair-Manual
Make sure you manually delete the skyrim folder (inside the COMMON FOLDER):
C:\Program Files (x86)\Steam\SteamApps\common\Skyrim,
then use the steam websiute client to "DELETE ALL LOCAL CONTENT. Then use your skyrim CD to launch the NEW installation. If it tries to download the4 WHOLE game, stop the download and FORCE it to use the CD by clicking on the CD "install skyrim" link. After the main install is finished, then you let it download skyrim updates. Then follow the i nstructions IN THE SKYRIM REPAIR MANUAL.
the problem is i deleted all my mods and my nexus mod manager with it, is there a straight forward easy way to install it like you installed it the first time...?
