SLI function in nvidia control panel not showing.
MILTONIHADES
56
I cannot enable my GTX560 non-ti because there is no SLI Function in nvidia contorl panel... Before you ask: Yes the GTX560 non ti are thesame 1GB and yes i already connect the sli bridge connector also yes i did plug and tried unplugged the molex adapter below the motherboard and yes i tried to uninstall nvidia related drives and install the latest driver. now im here finding for answer i search 5hours in net and nothing can fix my problem. also GPU-Z said SLI is disabled.
My Specs:
Windows 8.1 Pro 64bit
Asrock A88XFatality+ killer
4x2GB DDR3 HyperX kingston
2x nvidia gtx 560 non-ti
a8-6600k processor (stock speed)
1tb wd blue hdd
FSP RAIDER 750W 80+SILVER
screenshots:
I see no mention of SLI support. In fact, I see no A88X chipset boards with SLI support.
"Supports AMD Quad CrossFireX, CrossFireX and Dual Graphics"
Also doesn't look like the board supports 8x/8x on PCIe 3.0 or 2.0, just PCIe 3.0 at x16 + PCIe 2.0 at 4x which is enough for crossfire, but not SLI.
Asrock is a shame. why would they put the term "SLI" if the motherboard doesn't support it. i thought it is SLI capable. now i can't do nothing but to change in AMD graphics card to do a crossfire. thanks for your help.
