SLI gtx 770's power supply help
Maybe a grain of truth, but in your case the answer is no, the unit you selected will be fine. If you were looking at tier-2/tier-3 units, you'd probably want to go for an 850w, but the XFX PRO 750 is more than enough for your build. Especially since you're not overclocking; even if you take your whole system to the limit you'll be fine.
It will work with anything but a heavily overclocked 3930k or similar. You need a tier-1 750w PSU for that setup and the XFX unit you've selected is just that. So as long as you're not going for 5GHz with an Intel Enthusiast series CPU, you're good to go.
