The GX650 is, at best, a mediocre power supply with just 2 PCIe power connectors and a single 12 volt 52 amp output:
http://www.hardocp.com/article/2010/11/22/cooler_master_gx_650w_power_supply_review/
A pair of GTX650Ti's needs about 27 - 30 amps. Figure another 10 - 12 amps for an OC'd CPU. Figure another 100 watts or so for motherboard, RAM, drives, and fans and I estimate that you will be running the PSU at around 85% load.
You could do it using adapters for the other two PCI connectors, but I would not recommend it. I would suggest a better quality 750 - 800 watt unit.
