Sli with 680 Directu II TOP 2GB.
KitsuHellscream
14
wanted to ask whether this could have a sli configuration of these two graphs already mentioned ...
NZXT Phantom White
Asus ASUS P8P67 Deluxe
Intel i7 2700k
16GB RAM RIPJAWS 1600
Thermaltake Cooling SpinQ
Power Supply: Corsair 1050W Modular
DirectUII 680GTX TOP (mentioned)
I would like to know whether to go since it takes 3 slots and 3 slots and spare me if any of the PCIE could put another graphics card ... Also if a configuration would be appropriate to do so.
Sorry my bad english.
You've helped me a lot, thanks for the help, this what I want because I'm Streamer, and I have a little graphical cut 1080p streaming (I have good internet connection).
2 680GTX would amount 690/Titan? The performance obtained over?
Depends on the MoBo and slot spacing....Asus WS series has 3 empty slots between the PCIE slots which leaves me empty slots between the GFX cards. Many boards leave ya no space even with a 2 slot version of a card.
You'll oft see SLI x 4 w/ little space between the cards and this should be no different if you have two empty slots between .... since the extra slot is to remove heat
It's working here:
http://www.overclock.net/t/1350548/asus-gtx-680-dcii-sli
No doubt upper card will run hotter and yta case cooling will be important here, more so related to be able t get enough cool air in the case and around the cards. I like to use cases that allow extra fans to be mounted behind the HD cages and this, (as well as side fans) helps alot.
