Slim case to Big Case
augustinep
30
Iam using Dell Vostro 270s slim tower desktop I want to change the slim case in to Big case for installing best graphics card
How to change psu if changing psu harms motherboard
If price of psu cheap......
if I move motherboard in to new big case can I use best graphic cards (when changing psu)
Alright, there is a lot of stuff you need to know about the power supplies. First how to identify it, it is a box in your case with a big fan on it and many wires coming out of it and plugged into the motherboard and everything else, such your dedicated graphics card. Power supplies, power your computer and are very essential. Power supplies are easy to install if you do the proper research before. This video: http://www.youtube.com/watch?v=LtSHYEgAeMo Aswell as many others will be your guide.
Depends on how much wattage you select and it's performance. You will need a high wattage power supply (600-700) depending on your CPU wattage and if you are going to install one of the best graphics cards like a gtx 980 or 970.
You can get more info about power supplies and what makes them bad or good ones.
http://www.tomshardware.com/faq/id-2520345/faq-crap-psu.html
You can also find out which are the best Power supplies for the money here.
http://www.tomshardware.com/t/power-supplies/
