Slimmest, quiet mid-ATX case with optical drive?
groigroy
5
Hi there,
I am about to start a new build, compact and quiet, with enough space for a decent GPU. I was looking at micro-ATX cases with the Nanoxia Deep Silence 4 as front runner, although some of its connections are a bit out of date.
But some ATX cases are almost as small as mATX ones. I would buy the Fractal Define Mini C if only it had one 5.25" optical bay, which I need. I like the clean minimalist style of Fractal and Nanoxia. Can anyone recommend a similar mid-tower, less than 215mm wide, with an optical bay?
Many thanks!
Some cases that you may want to consider (all are less than 215mm wide, with external 5.25" drive bay/s and fits ATX mobos). Most of these (not all) are designed for low noise (some have noise-cancellation padding, et. al.):
200mm wide:
Corsair - 100R Silent ATX Mid Tower Case ($56.98 @ Newegg)
205mm wide:
Thermaltake - Urban S31 Window ATX Mid Tower Case ($299.89 @ Newegg Marketplace)
White Version: Thermaltake - Urban S31 Snow ATX Mid Tower Case ($169.95 @ Newegg Marketplace)...
200mm wide:
205mm wide:
210mm wide:
Aerocool - DS200 Black Window E ATX Mid Tower Case ($99.95 @ Newegg Marketplace)
210mm wide:
RIOTORO - CR480 ATX Mid Tower Case ($66.20 @ Newegg)
212mm wide:
Silverstone - FT02B-USB3.0 (Black) ATX Mid Tower Case ($241.49 @ B&H)
