Slow Download Speed, But Fast Upload Speed (Not Solved)
InterwebsMC
60
Recently, my download speed has been very low compared to before. I usually get around 25Mb/s download speed, but I just tested my internet speed and this is my result:
Sometimes it will get as low as 0.4 Mb/s
and even at 13 Mb/s, the internet is really hard to use. Youtube videos spend a longer time loading than playing, I can't really play any online games because I lag everywhere. This started after my mom unplugged my router for a day and then plugged it back in. Before she unplugged it, it worked fine. After she plugged it back in, My download speed went down. The weird thing is, my upload speed and ping are the same as always. I was looking around for a fix and everyone said to disable WMM support, but it was disabled already.
Earlier today, I downloaded a folder and in the downloads section of Google Chrome it said that the folder was being downloaded at 35 KB/s.
This is getting really annoying and if anyone could help, it would be greatly appreciated.
People generally use far more downstream than upstream, so there's not much point in capping upsteam. Generally ISPs get a roughly equal amount of each once it goes past the DSLAM/cable transmitter.
Do charter specifically say it's a 250GB plan, or do they just say that there's a 'fair usage policy'. If the latter, calling up and complaining should be enough to get it lifted. If the former, you may need to pay for a larger plan.
sounds like your being throttled. its 1 thing to get a drop in speed at a busy time. but to go from 25 down to 13 then into kilobytes, thats something broken or done deliberately to reduce your usage. maybe you have gone over a cap.
best contact your isp and ask them to check the line.
Currently, we have our router/modem on top of a cabinet type thing in our living room that is probably 7 feet high, and my computer is all the way in my room so I don't really feel like bringing my computer, monitor, and all of the cables out there and moving around the router and modem.
I don't think it has anything to do with server hosting. My download speed was fine until my router was disconnected for 2 days. And besides, I tried another download, this time from mediafire, and the download started at the usual speed, and then a second later it went down to ~300 KB/s. Then, the next second it went down to ~250. An so on, until it was back to 35KB/s.
There was also something really weird that happened earlier on my iPod. I have an app that can download music/videos from websites, and I wanted to download a youtube video. I started the download and it started at 500KB/s, and went down just like the download from mediafire. The weird thing is this: I realized the video would take WAY too long to download, so I downloaded the lower quality version of the video. I forgot to stop the previous download and when I looked at the download progress, they were both downloading at 130KB/s. I also realized that if I would pause and then start the download again, it would go up to ~500KB/s and go back down again.
Would the "cap" reset monthly? Because, if so, then I don't see how I could have already gone through it.
I feel silly now 😛 I looked around online and I think you are absolutley right. Someone said that watching Netflix 4.17 hours a day for a month would be enough to reach a 250GB data limit. My family watches more than enough Netflix to reach that cap. Usually it totals to about 8 hours a day. I will check this when my mom wakes up, as she is the one who pays for the Internet. Apparently Charter has this thing where you can track your data usage, and my mom made the account so when she wakes up ill check the data usage. Before 30 minutes ago, I thought data limits were only for phones! That still doesn't explain why my upload speed is the same. And if this is the problem, do you think there is any way we can ask Charter to specifically increase the data cap?
run a tracert
open the cmd prompt with admin privs and type tracert www.youfavwebsite.com
look for ** timout if its your isp thats timing out phone them, if its another ip further down the list theres little you can do other than hope they fix it.
paste the results here if your unsure.
How can I post the results? Is there a way to copy/paste, or do I have to re-type it all?
Tracing route to www.google.com [173.194.46.81]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 6 ms 7 ms 6 ms 192.168.1.1
3 7 ms 8 ms 8 ms dtr04trcymi-tge-0-6-0-1.trcy.mi.charter.com [96.
34.34.94]
4 13 ms 11 ms 11 ms crr02trcymi-tge-0-7-0-5.trcy.mi.charter.com [96.
34.33.14]
5 20 ms 11 ms * crr02aldlmi-bue-4.aldl.mi.charter.com [96.34.36.
20]
6 17 ms 15 ms 17 ms bbr01aldlmi-bue-2.aldl.mi.charter.com [96.34.2.1
0]
7 16 ms 15 ms 16 ms bbr01chcgil-bue-4.chcg.il.charter.com [96.34.0.9
9]
8 * 19 ms 16 ms prr01chcgil-bue-2.chcg.il.charter.com [96.34.3.9
9 * 17 ms 15 ms 96-34-152-30.static.unas.mo.charter.com [96.34.1
52.30]
10 17 ms 17 ms 22 ms 209.85.244.3
11 * * * Request timed out.
12 * 16 ms 19 ms ord08s11-in-f17.1e100.net [173.194.46.81]
Trace complete.
I decided to ping www.google.com
Pinging www.google.com [173.194.46.84] with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 173.194.46.84: bytes=32 time=56ms TTL=53
Reply from 173.194.46.84: bytes=32 time=86ms TTL=53
Ping statistics for 173.194.46.84:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 56ms, Maximum = 86ms, Average = 71ms
