Question small droplets on my PC panel
Mar 14, 2025
Someone else already got the same issue here with almost the same cooler model
Im using a new EVGA AIO 240MM cooler, i noticed that after playing some games some type of droplets appear on my PC panel, They are sticky and spread, I took the PC to maintenance but they told me that the liquid had the indicated liquid and that they had put paper over the cooler and its tubes and that they were not wet after the tests.
But the only thing I changed was my computer's cooler. It doesn't make sense. They're identical to the ones in the other forum, which also had similar problems with the almost identical model.
Here is the forum I am referring to:
https://forums.tomshardware.com/threads/noticed-small-water-droplets-inside-computer-case.3465599/
There's only so much you can explain via text that you need to use other forms of media to illustrate what you're encountering. You might want to pass on images of what you're seeing.
You should also include the age of the AIO. That thread was back in 2019, I doubt you're going to get anything back from that thread's OP. I'm also assuming you're beyond the warranty period for your EVGA AIO.
If I'm not mistaken, it's like 2022..
 But I bought it and it's new.
Here is a photo
