Hi, yesterday the power supply of my pc got upgraded to a Seasonic GC-550. Please see last 2 posts in this linked thread for reference. https://forums.tomshardware.com/thr...h-for-1660-ti-1660-super-or-rtx-2060.3736344/
this morning, when I turned on the pc. There's a small "spark noise" when turn on the pc. The spark sound is similar to when you plug something into a wall outlet. The old PSU does not do this sound, so it has me a bit worried that some cables might be touching where they should not. Or something is out of place. Can't take pics of the inside of the case now, it's morning and I need to go to work in 30 minutes. But will take pics of the inside of the case when get back home.
btw, nothing smells burnt. The pc runs silently after that "one spark noise" on turning it on. The noise is not loud, it's a tiny noise when you plug something into the wall outlet, and the wall outlet makes a spark.
the temps also seem normal in HWmonitor. Is there something I should look for and where?
temps when gaming
temps when gaming
