Smallest case for hyper 212 eve
pcpro98
Commendable
Aug 26, 2016
8
Does anyone know what the smallest case will work with this hardware (£60)
GIGABYTE GA-970A-DS3P
NVIDIA GE FORCE 650 TI
COOLER MASTER HYPER 212 EVO
I would be grateful for some suggestions.
Any of these below:
Link to PCPartPicker for further details
I used the 2 main items when searching on PCPartPicker's website (Mobo/CM Hyper 212 EVO).
Was there something you had in mind?
You are limited by you ATX sized Mobo also, so hard to get smaller with that option. If you already have the parts, we can help you with trying to find something that fits your style. If you haven't purchased your parts, we can help you get into smaller options, if that is your ultimate goal. Intel has better options, TBH, but it all depends on whether or not you already have the parts or not.
Check the depth of your case. That cooler requires 6.3" of depth. My Cooler Master Scout 2 fits it with just a tiny bit of spare room. This is an ATX motherboard you've selected, so you'll need at least something big enough to support ATX and be 6.4"+ deep.
Hope this helps.
Define "smallest"
Length, width, height?
Your motherboard is a full atx size, so you will not fit anything really small.
The cm hyper212 is 159mm tall. A typical size.
Some cases have restricted height.
Do you already have the motherboard/cpu/cooler?
I might not have picked those parts.
Any of these below:
