Smallest mini itx case that can fit dual slot cards?
jwright201
108
I'm looking to build a tiny pc and I'm on a quest to build the smallest pc possible. I got a really good deal on an i5 2500k for $15, and i'll probably get the gtx 1050 when it comes out. judging by how small the 1060 can be, the 1050 will probably be just as small if not smaller(although most likely dual slot, so I figured I should build a tiny build around that tiny card). I was thinking about the coolermaster elite 110, but it could be smaller if it were sfx oriented, so its not the smallest it could be. Also the ncase m1 was a candidate but I ruled it out because it is nearly $200 USD (I'd preferably want a case under $100). Are there any cases that support a short dual slot card that are smaller than these 2 cases? (120mm watercooling would also be a big plus if possible)
I know of the dan a4 but it'll be awhile til it's out and still be in small supply. They'll probably just get enough this year for the kickstarter backers and only europe availability has been mentioned.
ok but isn't the rvz02 and node 202 smaller? plus I've heard that cube cases are actually more compact. Do you know any others?
It will really be going everywhere as I want this pc to be as portable as possible. Also I just discovered the Dan a4 sfx case, although it isn't released yet so I don't the price. If it is 100$ ish I am getting that case
Alright I guess I will just wait for the dan a4 in US and save up my money
