I was getting IO errors on large/long read operations on the hardware raid array in my fileserver. As the (Startech) controller didn't support SMART I had no idea as to the state of the disks, so I pulled it apart and hooked the disks up to the SATA ports on the motherboard.
I'm having issues mounting them, but that's another story, in the meantime I did get SMART working, and reporting. output attached for one disk:
The other disk also has 2 errors, I'll admit I didn't copy the output from that this morning.
Are these errors of concern? Could they be caused by the controller or cables? Or given the age (bought in 2015) and the runtime of the disk is at least 1410 days (~3.8 years) do I need to consider these disks are reaching end of life and plan on replacing them? I think the stats look okay, what would the seasoned experts on here suggest?
Code:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.9.0-9-amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA200
Serial Number: 45U78AWGS
LU WWN Device Id: 5 000039 fe2c34df2
Firmware Version: MX4OABB0
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jun 11 07:51:00 2019 BST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x85) Offline data collection activity
was aborted by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (14822) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 247) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 139 139 054 Pre-fail Offline - 71
3 Spin_Up_Time 0x0007 140 140 024 Pre-fail Always - 263 (Average 278)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 81
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 096 096 000 Old_age Always - 33922
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 81
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 338
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 338
194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 10/48)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 2
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2 occurred at disk power-on lifetime: 33859 hours (1410 days + 19 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 0d 3a d3 f8 0c Error: ICRC, ABRT at LBA = 0x0cf8d33a = 217633594
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 08 68 87 d4 f8 40 00 5d+19:55:48.038 WRITE FPDMA QUEUED
61 28 60 17 d4 f8 40 00 5d+19:55:48.038 WRITE FPDMA QUEUED
61 18 58 a7 d3 f8 40 00 5d+19:55:48.038 WRITE FPDMA QUEUED
61 10 50 37 d3 f8 40 00 5d+19:55:48.038 WRITE FPDMA QUEUED
60 20 48 5f 2f 88 40 00 5d+19:55:48.037 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 26763 hours (1115 days + 3 hours)
84 51 3f 30 60 1b 0f Error: ICRC, ABRT at LBA = 0x0f1b6030 = 253452336
61 40 50 af 94 1b 40 00 5d+19:20:42.562 WRITE FPDMA QUEUED
61 40 48 6f 8f 1b 40 00 5d+19:20:42.562 WRITE FPDMA QUEUED
61 40 40 2f 8a 1b 40 00 5d+19:20:42.561 WRITE FPDMA QUEUED
61 40 38 ef 84 1b 40 00 5d+19:20:42.561 WRITE FPDMA QUEUED
61 40 30 af 7f 1b 40 00 5d+19:20:42.557 WRITE FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 33918 -
# 2 Short offline Completed without error 00% 33914 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
