Smart fan and Cool'N'Quiet settings?
enarchay
41
First, what exactly is the difference between Smart Fan and Cool'N'Quiet? Do either of these shut down my system if it gets too hot? If not, what function does that, and where can I find it in BIOS (and what should I set it to)?
Second, what settings should I put Smart Fan at? I wasn't sure. It gives the following options:
Smart fan target - 40c/104f, 45c/113f, 50c/122f, 55c/131f, 60c/140f
CPU minimum fan speed: 0.0, 12.5, 25.0, 37.5, 50.0, 62.5, 75.0, 87.5
Cpu fan PIN select: 3 or 4 PINs.
It said at the time that my system temperature is 43c/111f and my CPU temperature is 31c/86f.
What should I set these settings too and why?
