Agree with DMAN999. Some A and B series motherboards don't even support 3600mhz speeds.
Check the specifications of the motherboard in question, as well as their memory QVL - because even if you find a board that DOES support 3600mhz, the speed it'll run at may actually be lower, after which you'll likely have to do some tweaking of your own to get it to do so.
