Context: a four year old acre aspire v3-574g, that had never been cleaned before
Pretty stupid of me, I know. For some reason I thought it wasn’t really necessary to unplug the main battery. I didn’t touch anything apart from the heat sink, fan and case. I tried to be careful, but I might have inadvertently touched a component or two near the fan. Once I put everything back together and tried booting up the laptop, it didn’t start. Nothing on the screen, and even the charging/power on LEDs were off. Can someone give me an appraisal of the damage I might have caused? Could I have blown the motherboard, is it something that can be fixed cheaply, or will I just have to get a new laptop? Will the data on my hard drive be affected?
Thanks,
G
(I’ve read up fairly on the issue of laptops not booting up after being cleaned internally. One of the screws in my case seems to have worn out it’s threading, so I can’t open the laptop again to check for loose connection or the like, until I fix that. I don’t have any electric tools so might need to get a mechanics help for that eventually.)
Thanks,
G
