So i wanna make my first pc , i need opinions and help
Apr 3, 2018
12
So i wanna make a pc and here are the components :
LIAN LI ALPHA 330X Black SECC ATX Mid Tower Computer Case
CORSAIR CX750 (New) (CP-9020123-NA) 750W ATX12V 80 PLUS BRONZE Certified Non-Modular Active PFC Power Supply
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model ...
ASUS ROG Strix Z370-E Gaming LGA 1151 (300 Series) Intel Z370 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
SAMSUNG 960 EVO M.2 500GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E500BW
Intel Core i7-8700K Coffee Lake 6-Core 3.7 GHz (4.7 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I78700K Desktop ...
EVGA GeForce GTX 1080 SC GAMING ACX 3.0, 08G-P4-6183-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
DEEPCOOL 120mm High Performance All-in-One White LED Liquid CPU Cooler, AM4 Compatible, 3-year Warranty (CAPTAIN S-120W)
Can anyone tell me what else i would need or if there is anything i can upgrade and if it will be good for gaming
For Asus
Rog maximus> rog Strix > Asus prime
Prime is their budget line, Strix is more of a glorified prime with a bit more feature and maximus is the top of line Asus stuff.
I don’t have the spec sheet with me, but I think prime and Strix uses very similar if not the same vrm setups.
To add to the incompatible motherboard, you've also chosen a relatively low quality PSU which is never a great idea when you have a powerful build. What's another 30 bucks for the most critical component when you're already spending so much.
The most common recommendations are the EVGA supernova G2/G3, Seasonic Focus plus, Corsair RMX/RMi/TX, also Superflower Leadex I/II. Any of these in 550-650W would be a much better choice.
ye i updated the motherboard and ty for telling me about the PSU
what about the
ASUS PRIME Z370-A
For Asus
