Question So, if I buy a PC without a harddrive, does it come a loose cable with the power supply?
Aug 1, 2019
Im going to buy a pc, but i want to keep my HDD, so im going to buy the new pc without the HDD and add my HDD to the new pc.
I will use my SATA cable, but my question is if is going to be a loose cable in the power supply for my HDD. Ty for the attention.
Aug 1, 2019
Usually you will get 1-2 sata cables with the motherboard. You can check on the motherboard spec list and see if you can see it. If you can't, i would recommend you buying one to be save (its around 2-3 $)
