[SOLVED] software for monitoring temps
did you look at this?
you can add icons to toolbar or charts to track certain temps using HWINFO, probably integrate it into apps that show temps on desktop - I am a simple person, I just do the easy things.
i used tips in the video so i can see cpu, gpu & hdd temps at all times in system tray
it should have an entire section for the gpu
but I assume PCIEX16_1 would be the gpu if it doesn't show anywhere else. that is going to be a sensor on the motherboard , now that i look at mine.
GPU section at bottom of all the sensors, scroll down more. show me a screenshot
you are looking in the motherboard sensors area
labels vary
My CPU Fan is actually a water pump, i am not running CPU fan at that speed or I would hear it :)
