Just got my new system up and running. My system drive is a 256 gb SSD, and I have two internal 3TB HDDs...one data and one backup. I also have an external 2TB USB HDD that I will use as a backup (albeit, less frequently than the internal backup). Because of the SSD, the power management for turning off hard drives automatically is disabled. This is recommended for running SSDs. Therefore, both of my internal HDDs are constantly spinning.
I would like to find a solution to manage the HDDs, but at the least find a solution to turn off (or just stop spinning) the internal backup drive, since it is not used very frequently. It would be nice to do this with the external HDD, but I'll probably just unplug it when not in use...easy enough.
I searched for any software/utilities to do this, but couldn't find anything. Other users have the same idea, but it doesn't seem like they found a software solution either. As of right now, I've determined my options are:
1) Manually unplug/plug internal drive. Requires access to the inside of the case.
2) Get a mobile rack for my case (eg Vantec), which allows me to remove the backup drive or just power it off from the mobile rack.
3) Wire in a power switch for the drive. Cheap, easy, simple.
4) Get an external enclosure that has a power switch on it.
Out of those choices, I would probably choose 3), just because it is cheap and I'm not adding more components that have potential for noise (like the mobile rack that has a fan in it).
Ultimately, a software solution would be awesome! Thoughts?
