Software for syncing aura, icue and cam
Stressedguy12
Commendable
Dec 9, 2016
12
Hi! So i just got my corsair rgb pro ram. I wonder if its possible to sync this with the rest of my setup.
Specs:
Intel Core i7 7700k 4,8 GHz
Corsair Vengeance LPX DDR4 2x8GB 2400MHz (icue)
Corsair Vengeance RGB PRO DDR4 2x8GB 3100MHz
Msi B250 Krait Gaming LGA 1151
ASUS GeForce GTX 1080 Strix Advanced Gaming 8GB (aura)
NZXT Kraken X52 (cam)
Specs:
Hey Stressedguy12,
There has been a project going on for sometime to do exactly this. While Aeacus was not completely correct in saying that it cant be made a group over at github has done elements of what you want using the various manufacturers API's. You can check their progress and even download and install the work in progress. It may not do everything you want but definitely worth a follow as hopefully they will be able to unify at least the most common platforms in this so very divisive RGB market.
https://github.com/DarthAffe/RGBSyncPlus
