Software to test network speed?
G
Guest
Guest
Archived from groups: comp.dcom.lans.ethernet (More info?)
We have a Routing Switch that is connected by fiber to 4 other switches. I
want to run a test on the other end of each switch to see if I am getting
the full bandwidth. Anyone have any suggestions on software to use to test
these connections?
> these connections?
For a quick check try Qcheck
<http://www.ixiacom.com/products/performance_applications/pa_display.php?skey=pa_q_check>.
The console requires Windows but they have endpoints for just about
everything you're likely to encounter. Nice piece of freeware.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
> other switches. I want to run a test on the other end of each
> switch to see if I am getting the full bandwidth. Anyone have
> any suggestions on software to use to test these connections?
I typically use `ttcp` with options.
-- Robert
BINGO! - you beat me to it -
We use QCHECK and it's great!
"J. Clarke" <jclarke@nospam.invalid> wrote in message news:<chqegd027e7@news4.newsguy.com>...
> > these connections?
You can also use ttcp. It's available for many platforms as a java
tool and for windows as ttcpw.exe. Lets you test udp and tcp in
varying packet sizes. Of course, you may find the bottleneck is the
local nic/cpu.
-Chris
On 14 Sep 2004 10:28:01 -0700, mike.farnham@co.manatee.fl.us (Mike
>> > these connections?
