[SOLVED] Soldering help with Steelseries Arctis Pro
Take a look at the soldered connections on the Left side.
Could serve as a reference - may be a mirror image or otherwise provide some guidance.
Sketch out the wires for both sides and mark using the printed solder point labels (e.g., SPK_R+1, R_LED_G+) Color code your sketch to match wire colors.
Google words such as "Headset Earphone schematic". Limit to images
Example:
https://www.petervis.com/Vintage Misc/Vintage Headphones/beats-ep/wire-replacement.html
Look at a few such diagrams, images, photos, etc. You may discover a pattern that matches your Arctis Pro.
Example:
