Soltek FX5200 HELP!
samuelgomes
Hey fellas! I just bought a Soltek FX5200 video card (something that most of you may dispite! =oP), but here in Brazil, Ati's graphics cards are too expensive, i just moved to a new apartment so i kinda poor now! =oP
anyway, i installed it on my PC (p4 1.5, intel D845WN, 512PC133, Samsung 40GB), games like Counter Strike (OpenGL) are getting fps = 60!!! I had a GeForce 2 GTS and fps = 100.
I really thing its driver issue, DirectX applications works really fine, like HALO or my 3D Max, much better than on the GTS.
What should i do?!
Thanks Anyway!! =oD
Well, frankly the old Geforce2 GTS might be a better card to run Counter-Strike on.
Are you sure you didn't end up with a 64-bit 5200? That'd be a pretty slow card...
And, hey! Next time, if you can't find anything local, consider buying off of ebay maybe...
________________
<b>Radeon <font color=red>9500 PRO</b></font color=red> <i>(hardmodded 9500, o/c 322/322)</i>
<b>AthlonXP <font color=red>2600+</b></font color=red> <i>(o/c 2400+ w/143Mhz fsb)</i>
<b>3dMark03: <font color=red>4,055</b></font color=red>
