[SOLVED] [Solved] Didn't start assembly (Aorus 360 M Pro + i7 9700 + KVR32N22D8/16)
Oct 8, 2019
7
On Input:
  1. Aorus 360 M Pro (rev 1.0, bios ver is unknown), (as MB)
  2. Core i7 9700. (as i7)
  3. Kingston 16 Gb (KVR32N22D8/16) (as Mem)
  4. Video on board.
On output:
System starting, quick single blink CPU led on MB, after that switch on led DRAM on MB - led is continuously light. Speaker didnt beep's, no post screen. System reboot automaticly after 3 sec approximatly, after restarts all steps repeating except reboot.
Made :
Change slots of mememory: state is unchanged;
I suppose, that bios is old and don't understant memory or CPU, but why there is no POST screen.
Please help to diagnose (complex conditions for grade A+: you havn't another memory bank, you havn't another gen 8 or gen 9 CPU and you havn't anther working system with comparable components).
The memory is programmed to JEDEC standard latency DDR4-3200 timing of 22-22-22 at 1.2V.
Motherboard has Support for DDR4 2666/2400/2133 MHz memory modules.
3200MHz is too fast for the motherboard.
https://www.kingston.com/dataSheets/KVR32N22D8_16.pdf
It does not appear the memory operates at anything under 3200MHz which is not a supported speed. Try using DDR4 2666/2400/2133 MHz memory modules.
Trouble is solved by replacing memory with slow memory bank.
The reason best explained by
