Solved - "Ethernet" does not have a valid IP configuration
Driz
Commendable
Sep 1, 2016
13
Hi all. I've been running on W10 for about a month or so since repairing my computer (replaced the motherboard/gfx card/psu) and it was originally on W7. The motherboard (MSI Z97 Intel LGA 1150 DDR3 USB 3.0 ATX Gaming Motherboard) came with an onboard Killer E2200 NIC. When I switched over to W10 it worked perfectly fine, no changes in speed, stability or service and then about 2 or 3 nights ago there was an update for my computer (I'm fairly certain it was for the xbox one wireless adapter drivers to be installed) and when the computer booted back up I could no longer connect to the internet. I've tried multiple fixes and read a bunch of other forums. Fixes I've tried include:
Disabling and re-enabling the Ethernet controller
Unplugging the PC for hours and coming back to it (with cords disconnected)
Resetting the router/modem (they're one in the same)
Reset TCP/IP settings
Flushed DNS
ipconfig /release and /renew (both of which result in negative feedback)
/ping 127.0.0.1 (also negative results)
Entering adapter options and disabling IPv6 as well as ISATAP adapters in the device manager
Going into Registry and making sure that all users had full control in the appropriate NSI folder
and quite possibly a few other things that I have not done.
I ultimately conceded to the fact that it could be the onboard card is just dead (unlikely with a new motherboard < 2 months old but quite possible) so I went out and picked up a USB to Ethernet adapter, installed the drivers via USB and STILL have the same issues that I had before. I no longer have any clue what I need to be doing and I'm at my wit's end. If anyone could help out that would be wonderful. I'll edit (or post) with my ipconfig /all shortly. Thank you!
Edit: ipconfig /all (latest result after changing to the USB Ethernet adapter)
C:\WINDOWS\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : User-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek USB GbE Family Controller
Physical Address. . . . . . . . . : 3C-18-A0-41-B8-A4
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IPv4 Address. . : 169.254.29.22(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Enabled
