I have two monitors, one of which is 1280 x 1024 and is displaying the "input signal out of range" error.
Yesterday, I changed the resolution to 1920 x 1080 (not a good idea) and there was an "Input Signal Out of Range" error. So today I changed the resolution back, but the problem is still there. I've tried lowering the resolution all the way down to 800 x 600 but the problem still persists.
I've noticed that under the "advanced display settings", the active signal resolution (I guess the resolution that that the GPU is trying to send) is still 1920 x 1080, despite me setting the resolution back to its previous value, which is why the error is occurring, but I don't know why the GPU is doing this.
However, this problem is only present with "extend these displays" with the dual monitors. If I select "duplicate these displays" so that the screen is identical on both monitors, the monitor works fine and the active signal resolution goes back to 1280 x 1024 so works perfectly.
How can I fix this so that the monitor actually works again with "extend these displays"?
Many thanks in advance 😀
OS: Windows 10
GPU: GTX 1050ti
OS: Windows 10
GPU: GTX 1050ti
