[SOLVED] [SOLVED] power sw / reset sw
Elliah246
157
5
585
I mounted the cpu power cable in the powersupply but trying to connect it to the mainboard is where i struggle.
The mainboard has two slots where i could mount the cpu power cable but how do i know which one to use? Or do i use both and split the cables?
What do i mean by split the cables? Well the cpu power cable has two ending the one that has split connectors and the other single connector.
I dont even know which ending of the cable goes into the mainboard and which into the power supply.
See pictures below:
Also did i mount power sw and reset sw correctly? The manual sucks with instuctions for this.
My GPU amd readon rx 9070 sapphire pure has an ARGB connector. Is this for RGB lightning?
Or does it also handle other data? If its only rgb and i dont need that, safe to leave it unplugged?
How did you solve it? Please let others with the same issue know how to fix it!
I read all the manuals, but this time without skipping anything.
Searched the web.
Looked into some pc builds from others.
Used that thing in my head you call a brain to think what makes sense and what doesnt.
It wasnt that difficult figuring things out after motivation was reanimated.
