Hi, brand new computer, I'm legit getting nuts. I'm a freelancer and I got a newborn baby, losing money with each day I can't work (game developer), getting desperate
Context:
- New parts: i7 14700k + Maxsun Z790 + 64gb ram corsair 6000mhz + MSI MAG A850GL 850W.
- Old parts: RX590 TDP 175W (need to use old GPU, I test games). Cleaned and put new thermal paste, stress tested, works flawlessly on old build.
Extra info: Updated bios, drivers, everything. Nothing is overheating. Bios is stock. No OC/undervolt.
Problem:
- 14700k computer crashes with the RX590 plugged in it - crashes on idle, on benchmarks, on almost everything (chrome/etc). Usually after 1-2 hours of use. Mouse/image freezes and I need to reboot manually. No sound, no sparks, nothing. Fans keep spinning, leds keep spinning. Only thing that makes the computer "reset" is holding the power button. Most of the crashes happen at idle/chrome/low load. Computer rarelly crashes on benchmarks.
- No bluescreen, no error messages, no auto-reboot, nothing. Just mouse + screens frozen every single time.
- After crashing WIN+CTRL+SHIFT+B doesn't work at at all, system is 100% stuck (pressing numpad/numlock doesn't work as well after crash).
- Fastest way to crash is by running AMD Stress test - it crashes in like 2 minutes. If I leave power limit to 50%, it takes a lot longer to crash but it still crashes!
Tests I made:
- 14700k system is stable if I put my old PSU in the new system (old model CX600M, 10y) even with the GPU at 115% power limit and using power adapter cables (which makes no sense to me).
- 14700k is 100% stable without the GPU and with the new PSU MSI MAG A850GL 850W, EVEN WITH HEAVY OVERCLOCK.
- RX590 works flawlessly if I put it on my old computer (4770+H61M+16GB ddr3 + CX600M).
- Tried switching motherboard PCI-E mode to gen3/4/5. Still crashes. Tried also disabling C-STATES, making voltage higher, also nothing.
- Memtest, processor test, all 100% perfect.
- Intel processor diagnostic tool 100% perfect.
- 5h stress test on my RX590 on my old computer, 100% perfect, temps low/stable.
Questions:
- What the hell is going on? Is it the psu? It's brand new and got 10 years warranty, A rated.
- Is there any "chance" the old RX590 is not compatible with the newer board z790?
- This PSU has a 16pin pci-e cable, I wonder if I should buy a 3060/4060 to test if it works, maybe the new PSU is optmized for gen5 pci? Does this make sense?
- Is it worth the effort to put the MSI MAG A850GL 850W (new PSU) into the old computer that's been stable for 10 years (4770/rx590)?
What should I do? Thanks a ton!! Crashes are Kernel-power mostly.
Logs from the crashes - they are either kernel related or igccservice/cplspcon crashes that happen AFTER the crash.
Context:
Problem:
Tests I made:
Questions:
