Some advice on upgrading and possible PSU issues
Marlon_5
Commendable
Jun 6, 2016
6
So I have had this set up since about 2012 I upgraded the GPU a couple years ago. (full system info at bottom)
I am pretty sure I need a new PSU, I am experiencing crashes while gaming getting this log in event viewer "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly." while Gaming or running furmark. My temps are not getting above 55C.
EDIT: prime95 also caused the system to crash
So since I'm buying a new PSU I figure I might up grade more stuff while I'm at it. I'm willing to spend about 500$.
I use to keep up with the latest stuff but have been out of the loop for a couple years so bare wit my ignorance.
I am thinking of upgrading GPU and adding some more RAM but was wondering if my aging CPU needs a upgrade also.
So my questions are am I right on the PSU and what do you guys sugest I spend my money on while upgrading what are my priorities? Or should I start saving to start from scratch at this point?
Thanks in advance!
So here are the specs:
Main Circuit Board b
Board: ASUSTeK Computer INC. P7P55D LE Rev 1.xx
Serial Number: MT7098K22102921
Bus Clock: 133 megahertz
BIOS: American Megatrends Inc. 0502 09/09/2009
Processor
2.67 gigahertz Intel Core i5 750
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Not hyper-threaded
Memory Modules c,d
4088 Megabytes Usable Installed Memory
Slot 'DIMM0' has 2048 MB
Slot 'DIMM1' is Empty
Slot 'DIMM2' has 2048 MB
Slot 'DIMM3' is Empty
PSU:
Mastercool RS-500-PCAR3
Graphics Card Manufacturer - Powered by AMD
Graphics Chipset - AMD Radeon (TM) R9 200 Series
Device ID - 6811
Vendor ID - 1002
SubSystem ID - 3050
SubSystem Vendor ID - 1462
Revision ID - 00
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 2.0 x16
BIOS Version - 015.041.000.000
BIOS Part Number - 113-C6300100-X01
BIOS Date - 2013/11/06 00:15
Memory Size - 2048 MB
Memory Type - GDDR5
Memory Clock - 1400 MHz
Core Clock - 955 MHz
Total Memory Bandwidth - 179 GByte/s
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
No real preference. Any recommendations for processor mother board and PSU? Something that would allow me to upgrade my GPU maybe in a year or so?
I'm guessing start with psu since this is most probably what's causing the crashes at the moment.
Do you have a price range? And are you planning on heavy game play or more casual?
Right now I'm looking at spending 500 tops. I'm looking at Corsair CX 500 for PSU.
I would be using the PC for gaming. I'm a casual gamer only maybe get a few hours a week I n but I like them to count.
So I'm better off upgrading mobo and CPU over GPU?
