I am trying to set up my first PC build but I've run into problems that I don't know how to solve.
I have a EVGA Z270 Classified K motherboard together with a Intel i7 7700k processor, 4*16GB of HyperX 2400 RAM and a 1080 TI and for memory I have a 512 GB Samsung 960 EVO PRO
My PSU is a Corsair CX 750M
I have everything plugged together, but I didn't yet try to install Windows. I was hoping when I start it up there will be something on the display. I tried to plug my display in using the onboard HDMI and the HDMI on the 1080ti. However, the display does not receive any signal. The Motherboard shows the code "AO" which as I understood it would not be too bad.
In the beginning I forgot to plug in the CPU ATX power cable. There are two connectors on the motherboard, but I only got one on the PSU. Not sure if that is the problem and not sure if that can be the problem if the motherboard shows "AO".
I am hoping you guys can give me some help on this.
