SOMEBODY HELP ME with gtx 660
BaddGammer
23
today bought a GTX 660 Synergy Edition 2GB...i installed the card as usual....i used a DVI to VGA adapter and connected the 6pin power connector....but when i turn on the pc the fan in the GPU,psu and everything runs fine,but my monitor displays CABLE NOT CONNECTED..What to do please please help me....
My Spec
core i3 3220 3.3GHZ
8GB corsair Vengeance 1600MHZ
AsRock H61M-S1
Basic 450W psu
Zotac GTX 660 2GB Synergy Edition
If you're adding a dedicated video card for the first time, you were running off the the integrated graphics on the CPU.
Did you go into your BIOS and disable the integrated graphics?
If so, use an HDMI to test on a TV or other display.
mine is ACER p195hq 18.5",not sure whether it has HDCP
It had two DVI ports,and i tried on both Still getting the same response...i also tried HDMI to VGA adaptor too
try and find another monitor to check....i dont think that the problem is with your card...I'm sure that your monitor doesn't support hdcp..same thing happened to me once with aoc 15 inches monitor.I had to change my monitor..now i have a hp lv1911..it solved the case..
i think i found the reason for the problem,actually my mobo works on UEFI Bios..but gtx 660 not support UEFI...what to do now??
What? That is not correct, the 660 does work on UEFI motherboards.
