Sony camcorder as webcam - timeout problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: rec.video,rec.video.desktop (More info?)
Hi all,
I'm using my TRV38 as a webcam, seems to work just fine so long as I keep it
"active". If you don't it times out after a few minutes. I don't know
exactly what the duration is but it does time out. I'm streaming to my
desktop via usb.
Does anyone know why it's doing this? I can't seem to find a menu option to
toggle the timeout either.
Thanks,
Kevin
It should stay on indefinitely if you don't keep a tape in it.
"Kevin" <kevin@xxvwkebxyz.com> wrote in message
news:OTf9e.2275$r53.268@attbi_s21...
> Hi all,
it
> desktop via usb.
to
> Thanks,
> Kevin
That is the secret with all the Sony's I have worked with.
With a tape in it, it times out, no tape, it will stay on all
the time.
mikey
"PTravel" <ptravel@ruyitang.com> wrote in message
news:3clgsuF6nppl2U1@individual.net...
> > Hi all,
keep
> it
> > desktop via usb.
option
> to
> > Thanks,
> > Kevin
Kevin,
> keep it "active". If you don't it times out after a few minutes.
Removing the tape should prevent the camcorder from shutting off after 5
minutes or so.
You may also need to disable the "screensaver" mode in the menu options.
Anthony
Thanks guys! looks like it's fixed.
BTW, do you have any recos on good webcam software? Something that I can
keep on for hours. So far I've only tested with AOL and MSN IM.
Thanks,
Kevin
"HerHusband" <unknown@unknown.com> wrote in message
news:Xns963E45247CCD4herhusband@216.196.97.136...
> Kevin,
> minutes or so.
> Anthony
Kevin,
I haven't used my camcorder as a webcam, but I like "Scenalyzer Live" for
both regular capturing and time lapse work.
Anthony
