Sony usb wireless LAN adapter alternative
paula_l_j
13
Hi I have a sony blu ray player that's LAN ready, says it needs a sony UWABR100 usb wireless LAN adapter to access the internet. This seems to be discontinued and what I can find is $200+ and way over priced. Big w use to stock them for under $100. Tried the larger electrical stores.
I've tried to use a asus wireless adapter for the PC but it won't recognise. I've read it will only work with the UWABR100. Also tried a dlink wireless n 150 mobile broadband router dir412 (as I have one sitting here unused) as someone mentioned to try and use a bridge, has Ethernet port in the bluray player.
I'm unsure if the dlink router I have can be used as a bridge, I'm not very PC smart but tried to log into the dlink router but it won't display the page. I can log into my belkin n300 wireless n modem-router which is what I'm using for my internet usage.
Any help is appreciated.
You might also want to look into powerline adapters. That would give you a nice stable connection without stringing cables all over, or worrying if the wireless signal is gonna be good.
http://www.mwave.com.au/networking-wired/ethernet-over-power-eop-wired
The first one listed would probably work fine.
http://www.mwave.com.au/product/tplink-tlwpa4220kit-300mbps-av500-wifi-powerline-extender-starter-kit-ab55609
is a bit fancier, but gives you extended wireless coverage, and 2 ethernet ports at the far end.
Yes that's it. Basically they plug into your power outlets and use the electrical wiring as your network cable.
Very easy to set up.
