Sony Vaio wont connect to my wifi help!
kateradliff
11
Okay so I have WiFi. My moms laptop connects fine. My Sony vaio won't. The WiFi switch is on. When I try and connect it says limited or no connectivity with a yellow triangle. Please help. School starts soon and I need my computer to work!
Now that reminds me when I clicked diagnose problem it did say something was wrong with my ip address. Yeah I have access to my moms laptop.
Someone said plug in an Ethernet to my box and comp and it'll fix my problem. Is this true?
Okay. Maybe your's DHCP on router is turned off. Try to connecti with cable to your router to see if there is any connection. If works, then go to you control panel again, and look up for IP settings on Local network adapter. It will give us a clue about your IP range.
this is the same my situation of my laptop vaio also please help me...i cant connect the wifi...
