Sony Vegas Pro 12 Rendering Freeze and Stopped
thejermjermboy
Hi Guys, I was just messing around with Sony Vegas Pro 12 the other day, and I actually made a great Minecraft Video with it. I tried to render it and upload it to YouTube, but it didn't let me. This is a 20 minute video and the bar just freezes when I try to render the video.
The other day, I tried rendering a 15 second intro video, and it worked fine. I picked the setting as Internet 1080p HD, and I do not know why it doesn't work anymore
The bar usually just freezes at 86% or halfway and more, I have no idea on how to fix this. I'm desperate to upload the new video I made
My GPU : AMD HD Radeon 6780
Processor: Intel Core i5 3.10GHz
RAM : 8GB
Here's a screenshot:
http://i813.photobucket.com/albums/zz56/jeremylesmana/VegasPro12Problem.png
Sleepyhead Media even after almost 2 and half years since your solution was posted on this forum to solving the rendering freeze issue, your solution solved my problem perfectly, no more render freezing at 30%! yay !!!! THANK YOU for offering that genius fix. I'm so friggin happy my project is saved and can be completed. Rock on dude. Cheers!
Thanks! Your solution helped me.
I tried as many solutions as I could read, including Sleepyhead Media's solution, and none of them worked. In my case, and possibly yours, it turned out that there was a problem with one particular clip. To find that clip, bisect the project, copy each half to a separate project file, and render both. If they render fine, then put them back together and you're done. If there's still a problem, then repeat this process. Keep repeating until you have a bunch of single clips that don't render properly. Upload the problem clips to Youtube, download them with clipconverter.cc, and replace the problem clips with these downloads.
